SailNet Community - View Single Post - Solo Mast Stepping System
post #19 of Old 11-06-2013
Rhys05
Rhys05's Avatar
Re: Solo Mast Stepping System
Originally Posted by SHNOOL View Post
A frame stays put, mainsheet tackle to raise the mast... it's so easy, that you stand, by the mast, pull with 1 hand, and steer with the other..... by the way works better if you put the mainsheet side AT the mast. Stupid simple, and fast. 4:1 works fine for my 31ft mast that weighs in a 70lbs.
SHNOOL:
I like this system, especially since your boat and mine are nearly the same size, with my mast maybe a bit heavier. A couple questions: Do you have the bottom of the A-frame secured to the boat? I'd be concerned with it slipping out under load, but perhaps the cross member just pushes up against the cabin? Are you just attaching the tackle to the spinnaker bracket on the mast? Do you have any lateral support for the mast, or are you just relying on the fact that the A-frame won't swing side to side to keep the mast centered as it goes up/down?
Thanks!
Brandon
S2 7.9 - Fast, Fun, and Beautiful!
Rhys05 is offline
The Following User Says Thank You to Rhys05 For This Useful Post:
Kielanders (11-08-2013)
