SailNet Community - View Single Post - C&C 35 MK III shower installation
post #2 of Old 11-11-2013
jsaronson
jsaronson's Avatar
Re: C&C 35 MK III shower installation
Congrats! I own an 83 Mk III. I hope you enjoy yours as much as I enjoy mine.
You should sign up at cncphotoalbum.com for C&C specific questions.
I have a FWC engine and hot water heater. If the engine is running I have a good supply of hot water. A 6 gallon heater makes for a quick shower dockside!
If there is a teak grate in the head the space below that is the sump. There should be a pick-up and hose on that leads to a pump under the sink. I believe the discharge is next to the bilge pump discharge on the port side. There is a pull switch and a separate breaker for the shower sump. Had to replace my pump this year.
jsaronson is offline
