SailNet Community - View Single Post - C&C 35 MK III shower installation
post #3 of Old 11-11-2013 Thread Starter
Saltaire1012
Re: C&C 35 MK III shower installation
Thank you. I'm planning on installing a 6 gallon ISO Temp, all stainless steel water heater (since it will be salt water running throgh it) so it's great to know that will be sufficient. There is a sump under a grate but no hose leading out from it. From what you wrote it looks like I'll need to run a hose from the sump to the space under the sink and then run the outlet hose to the sink drain thru hull.
Thanks again for the input.
Dave
Saltaire1012 is offline
