SailNet Community - View Single Post - looking for past or present owners of 1970 through 73 cal 27s
post #8 of Old 11-13-2013 Thread Starter
captain jack
captain jack's Avatar
Re: looking for past or present owners of 1970 through 73 cal 27s
Originally Posted by MichaelAngel442 View Post
Ok - Lets take this one at a time. First ~ Congrats on acquiring a pronominal boat. These boats are sturdy, quick, a safe cruisers. I absolutely love mine. With that said, lets start.
it's good to know they are a good sailing boat. I will be sailing on the Chesapeake and it can get rough, sometimes.
1. The door to the birth is a two part door separating in the middle. You should be able to locate the track as they are right on the wall where the bed begin right by the vbirth cousins. These doors slide in opposite directions to open and close. I'd be happy to take pics and measurements as you require to help you along.
I did see the track. I didn't realize it was a split door, though. I thought it as a single panel. I don't need measurements, though. if you are going to take interior picks for me to look at, that will be good enough.
2. The head is a portable head with access to external plumbing to extract waste if desired. I simply use mine as a port-a-potty. Emergency
/lady use only. lol I can send you pics and have documentation that came with boat. I'd be happy to copy and email if you like.
really? that would be great. my email is motorcyclejack2@aol.com. thanks. that would be a big help. so, what do you think about the tank under the cockpit sole? is there one on your boat?
3. The handle to starboard, right on the cockpit bench is actually the lever (white ball on end of handle) for the transmission on my boat; forward (all the way forward), neutral (middle), and revers (pulled all the way aft). I have documentation on this as well. I have a dry bilge as well and there is a whale pump in the cabin located on the bench wall on the starboard side.
I don't have a transmission. it's set up for an outboard, not an inboard. but that does sound like the handle. when you say a whale pump, I assume you mean for the bilge?
4. I don't have any pics of the interior, but I will take some for you and post them.
thanks. I appreciate that. it'd be a huge help.
I hope this helps.
Its nice to meet you as well and look forward to learning more about your boat.
Question: Your boat is a 1971 correct? Mine is a 1970 (1st design) My hull number is 101 (Very first design of CAL to have an inboard motor.
What type of engine does your have?
Thanks again and nice to meet you.
Michael
yes. it is a '71. I didn't know that about it being cal's first inboard. that was an option, though. one that the original owner of my boat didn't opt for. thanks for your help. it's good to know i'm not alone out there. lol. I don't know my hull number. I couldn't find the HIN. the title just has a 4 digit number there. it's 107-something. maybe 107-9. I can't remember. I will have to look.
thanks again
captain jack is offline
