SailNet Community - View Single Post - Best way to soundproof engine compartment?
post #21 of Old 11-13-2013
mitiempo
mitiempo's Avatar
Re: Best way to soundproof engine compartment?
Originally Posted by Dave_E View Post
There are 2 kinds of marine engine compartment insulations. One is for gas, the other for desiel. I just redid my doghouse... it's not that hard. Good sturdy putty knife took off the old stuff. Sanded down the old glue spots with big grit paper. Use spray glue in a can MADE FOR FOAM. Found a can at my local hardware store. The new insulation (as mentioned) is pricey. Don't skimp if you can, you'll be glad you didn't. Cuts with a good heavy pair of scissors (might have to borrow your neighbor's jocko kid though) :-)
Dave
Spray glue is used in conjunction with a fastening system supplied with the foam. The glue by itself will not hold the weight long term.
Brian
mitiempo is online now
