SailNet Community - View Single Post - Conn. River to Maine
post #2 of Old 02-12-2007
sailingdog
I hope you have a good drysuit, as the weather will have the potential to be really quite nasty in early March. I would recommend getting this book, which is an excellent resource for pretty much your entire trip. Be aware that many marinas are either closed or offer much reduced services for the winter, as the season doesn't generally start until April 1.
I would also look to rent an EPIRB if you don't currently own one. BoatUS/West Marine has an EPIRB rental program that is fairly reasonably priced. Otherwise, you can buy an ACR GlobalFix GPS-integrated EPIRB for about $700. I'd also signup for BoatUS's TowBoat program... just in case.
I would also recommend that you do the first section as coastal hops, and get as familiar with the boat, how to reef the sails and how it is rigged as you can. Definitely want to take the Cape Cod Canal, versus going around the Cape. Once you're clear of the Cape, you could go straight up to Cundys Harbor, rather than coast hopping.
My guesstimate is that the trip is about 275 miles or so...by the most direct route, using the CCC. Winds along the southern coast of CT, RI, and MA, will probably be predominantly westerly, so you'll have that in your favor. A run to Buzzards Bay and the entrance to the Cape Cod Canal, and a beam reach up to Maine... if you're lucky.
Two major questions for you
—how many days were you planning to take to move the boat??? and are you going to have an experienced crew???
sailingdog is offline
