Old 02-13-2007
gc1111 gc1111 is offline
gc1111 is on a distinguished road
First make sure your RPM readings are correct. With diesels, unless you have a mechanical takeoff, there can be lots of errors. Most tachs operate by measuring the frequency of the AC generated in the alternator. This requires calibration by an external reference. Best option is an optical tach. These operate by putting a reflective patch on the flywheel, shining a light on it and counting the returning light pulses. I got one off EBay for about $40.
If your RPM measurements are correct, fire the mechanic. You most likely have a problem with the govenor.
