SailNet Community - View Single Post - Boat stored in freezing rain
post #4 of Old 02-14-2007
sailingdog
Actually, I would worry about it. I'm guessing that your boat is on a cradle or boat stands, since it is on the hard. The weight of 3/4" of ice over the entire boat is a significant amount of weight and might cause problems with the hull where it contacts the stands or cradle. Also, if your boom is being held up by a topping lift, there is a significant amount of additional weight on it now.
The other problem is that the freezing rain that probably caused the icing could have caused damage by getting into small openings and cracks and then freezing, which would expand it by about 10%...
If the incoming storm adds additional snow and ice to what is already on the boat, you may have some damage... so I would try and get down to the marina to inspect as soon after the storm as possible.
sailingdog is offline
