SailNet Community - View Single Post - Need help getting propane fitting off
post #5 of Old 11-16-2013
overbored
overbored's Avatar
Re: Need help getting propane fitting off
if there is no propane in the system then you can heat the fitting up and it will loosen a lot easier. some pipe dope has a setting agent in it that glues the fitting on and the heat will break down the glue
"GOLD RUSH" PRINDLE 16
overbored is offline
