SailNet Community - View Single Post - Replacing my "engine room" blower?
post #22 of Old 11-18-2013
Delta-T
Delta-T's Avatar
Re: Replacing my "engine room" blower?
If you really want to know the actual CFMs, contact an HVAC company. They can measure using a Volumeter made for balancing systems.
You should be exhausting from down low and makeup air should come in high.
Here is an explanation of fan performance... ftp://www.nyb.com/Letters/EL-03.pdf
As far as what should the CFM be... if your engine compartment is 10 cubic feet and you are able to move 10 CFM, you would exchange all the air in that compartment in 1 minute. Running that fan for 5 minutes would exchange that air 5 times.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
