SailNet Community - View Single Post - High RPM further info and pitch and props
Old 02-17-2007
svsirius svsirius is offline
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
svsirius is on a distinguished road
Reduce the pitch on the max prop. I can be set as low as 10 degrees. Per max prop
A two degree change in blade angle will change the engine RPM by 13-15%, at the same boat speed.
so in your case 2 degrees equals about 300 RPM so a 2 degree change should do it.
details here:
http://www.pyiinc.com/index.php?sect...tallation&sn=3
Jon D
SV Sirius
Moody 47
