The S2 7.3 came in both a deep draft and shoal draft version. Here are complete specs.
SPECIFICATIONS
L.O.A. 23'10" 7.26m
D.W.L. 18'6" 5.63m
Beam 8'0" 2.43m
Draft Deep 4'0" 1.21m
Draft Shoal 3'0" .91m
Displacement 3250 lbs. 1474.17kg
Ballast 1300 lbs. 589.67kg
Sail Area 255 sq. ft 23.68kg
Mast Ht. above D.W.L. 31'8" 9.64m
Headroom 5'0" 1.52m
Berths 4
Cockpit Length 6'11" 2.08m
PRODUCTION 1978-1987 - 404 Hulls
The OMC sail drive IS problematic....but many had outboards which
would seem to be the best solution for your use. The OMC will be
expensive to take out and replace or seal up so I would suggest you look for a model
which has an outboard since the work will cost a good part of the value of the boat.
