SailNet Community - View Single Post - Prop Shaft Offset
post #2 of Old 11-20-2013
Faster
Re: Prop Shaft Offset
The shaft log, engine beds, and propeller strut are positioned in a line from the get-go.. if I'm understanding your question correctly, an engine repower, nor a realignment, couldn't change the designer/builders' original intentions.
Plenty of boats have propshafts off centerline.. C&C 30, Mirage 33, Ontario 32, as examples.. not sure if this is done to try to offset propwalk, address torque issues or if it's simply a way to make everything fit around the interior...
Are you saying that two similar vintage Pearsons are 'opposite'?? If so there must have been a factory mod during the production run.. are the interiors otherwise identical?
Faster is offline
