SailNet Community - View Single Post - Prop Shaft Offset
post #7 of Old 11-20-2013
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Prop Shaft Offset
That's what I was wondering - whether the new engine spins the prop shaft in the same direction as the old engine. As I understand it, the offset is an attempt to address prop walk by changing the angle at which thrust occurs. If the guy just had his engine replaced with one that spins the prop shaft in the opposite direction (as evidenced by the need for the new prop), that would amplify the prop walk, rather than reducing it.
If the assertion above (gas spins one way, diesel the other) is true, that could explain how it happened that the owner wound up with an engine that "wasn't set up properly" for his boat. Assuming that's the case, is there something that could be put in the drive train to cause the shaft to spin "properly"? Could the owner go back to the original prop but "just" run in reverse all the time? I'm not sure how the transmission would like being run in reverse, but...
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
