SailNet Community - View Single Post - Composting Toilets vs. Holding Tank
post #109 of Old 11-20-2013
MikeOReilly
MikeOReilly's Avatar
Re: Composting Toilets vs. Holding Tank
Originally Posted by casey1999 View Post
Can someone with "compost toilets" explain the following:
1. Can you put toilet paper in the composter? What if someone uses a lot of toilet paper- what happens?
2. What if a crew member has diarrhea? Seems like that would be a mess.
Hi Casey. #1. We toss paper in. Gets churned up and desiccates very well. We sometimes use "marine" TP, and sometimes just standard 2-ply. The key is to use as little as possible.
#2. Can't say it has happened much with us yet, but unless you were really flooding the compartment (in which case, you should see a doctor), I can't see it being a problem. Might make things a bit moister for a while, but I'd expect the fan would still dry things out.
Why go fast, when you can go slow.
MikeOReilly is offline
