SailNet Community - View Single Post - Navigation problem
post #23 of Old 02-22-2007
btrayfors
Capt Hand,
Yeah, easy, but I believe confusing on several counts.
First, the friends boat (Vessel #1) is on a COURSE of 036T, not a BEARING. His speed is 5 knots. His distance from your boat (Vessel #2) is 84nm. The BEARING to/from the vessels is ambiguous, the way it was presented. Normally, bearings are taken FROM your vessel, but the wording in the original is ambiguous, as in your solution. Either way, the answers provided do not agree with the computed values. Your boatspeed is 7 knots.
Let's assume that the bearing of 096T was, indeed, from Vessel 1 to Vessel 2. The reciprocal bearing, from your vessel to your friend's vessel, is then 276T.
If we then set up the problem in a conventional way, it looks like this:
Vessel #1 (friends boat): Bearing 276T Distant 84nm Course 036T Speed 5 knots
Vessel #2 (your boat): speed 7 knots
Required: course, time, and distance to intercept
According to the calculator (both of the aforementioned calculators agree):
Course to intercept: 314.21 T
Time to intercept: 10 hours 30 mins
Distance to intercept: 73.5 nm
Bill
btrayfors is offline
