SailNet Community - View Single Post - Mounting instruments into cabin: screws, and boatlife or epoxy?
post #8 of Old 02-23-2007
sailingdog
I would dig out the core for about 1/4" around the big 5" hole and then fill the space the core was in with thickened epoxy. Then drill the holes for the screws about 1/4" bigger than they need to be...and fill the hole with thickened epoxy, and then after it has set... drill holes for the actual fasteners to pass through.
BTW, you should probably have some sort of waterproof cover bolted or screwed to the back of the speaker... a 5" diameter hole can let a lot of water through if the sucker get taken out by a wave...
sailingdog is offline
