SailNet Community - View Single Post - C&C35 MK III Shower Sump
post #9 of Old 11-22-2013
Uricanejack
Re: C&C35 MK III Shower Sump
There is a hole in the sump Fwd inboard. How the hell you are supposed to get at it I cant figure out.
at one time my boat had hot cold pressure water the system must have failed and is all disconnected.
If I remember right it used to drain into sink drain. or reciculate. yuk.
I would like to refit water system if not to expensive.
Though you do tend to go through a lot more if you have running water instead of a foot pump.
I also don't have heat. so luxuries are likely to be by priority.
Uricanejack is offline
