SailNet Community - View Single Post - Why use a topping lift
post #2 of Old 11-23-2013
34crealock
Maine Dub
34crealock's Avatar
Re: Why use a topping lift
Once you get the main sail up, slack off the topping lift enough so you can mange the sail without pulling on the topping lift. When you sheet in the main sheet too tightly you will stress the topping lift if it is not slacked off enough. If you leave it connected with a little slack in it and you have to drop the main in a hurry it will keep the boom from crashing down. You can use a length of sturdy marine grade bungy cord on the boom end of the topping lift which will keep you from breaking it if you forget to slack it after raising the main. Enjoy
Al Pickering
PSC 34 #286
Coorie Doon
34crealock is offline
The Following 2 Users Say Thank You to 34crealock For This Useful Post:
Backloop1 (03-29-2014), Lemonshirt (11-26-2013)
