I do hope that they're bronze, not brass. Brass isn't a very good material for use on sailboats, as it tends to dezincify and then becomes very weak...rather quickly.
I don't know what to recommend for the exterior framing as I don't know what the boat or the ports look like... however, I can make a suggestion that you use a "wick" on the forward port to drain off the water that gathers in it. It is essentially a piece of cloth that overlaps the bottom of the port and hangs over the side...and it wicks the water out of the port whenever there is condensation or spray gathered there. Pretty primitive but fairly effective.
