SailNet Community - View Single Post - No Sailing Today
post #18 of Old 02-28-2007
christyleigh
christyleigh's Avatar
T34C - That is my first attempt at Shrinkwrapping. That's the good side - the other side looks like a taped up mess. I'm learning - next years will be much better. I saved the galv steel framing from the Fairclough cover I had for my c320 after selling the cover itself. I attached the frames to the stanchions using 'Framemaker Clamps' - http://framemakerclamps.com/ Great Stuff Cheap. I also used some basic conduit brackets from Home Depot for some other connections and extensions using conduit and a pipe bender. The clear shrinkwrap makes a greenhouse so between that and the reletively warm water heating blanket (only got down to 32 around the bay a couple weeks ago and now is on the rise) the weekend boat work is quite comfortable. If it does hit 45 this weekend it will be 60 in there. I'll never store on the freezing cold hard again.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
