Goose...good advice on the wire ties. As far as running the cable...it is easiest if you first run a weighted messenger string line down the mast and then pull the coax through with that. Also...when you drill the hole for the wire feed, put in a bushing to avoid the aluminum cutting through the coax BEFORE running the wire!
