SailNet Community - View Single Post - Pros and cons of steel sailboats
post #2306 of Old 11-26-2013
Jeff_H
Moderator
Jeff_H's Avatar
Bob,
With radiant heat in your floors, you need some roof mounted, solar glycol-water heaters that are piped into perhaps a 1500- 2500 gal storage tank with a heat exchanger to preheat the water going into your floors A water coil in your wood stove could provide further assistance. Even if that combo did not fully heat the water, it would reduce run times on your boiler by preheating the water going in. You would hardly see your propane guy after that.
I used to burn beach wood when I was camping. The trick is basically what Brent suggested, banking the damp logs so that they absorb heat from the fire and dry out before you burn the stuff. Splitting the logs help some and you need to rotate the logs periodically so all sides dry. By experimentation it seemed that it took roughly twice as many logs drying as you had in the fire to make sure that there were enough to burn continuously. The drying logs absorbed heat and would stay warm for a while after the fire burned down, and were useful to prewarm your sleeping bag before climbing in.
BTW, how is your aluminum origami Peapod coming?
Jeff_H is offline
