SailNet Community - View Single Post - Need some advice
post #6 of Old 03-04-2007
sailingdog
Painting the deck a color other than white or a very light off-white is usually a serious mistake. The deck will heat up a lot due to the sunlight hitting it. On some boats, using a darker color paint will cause the fiberglass cloth to "print through" because the resin will cure more as it heats due to the sunlight.
As for the Atomic 4. There are plenty of boats out there with gasoline engines... the main issues with the Atomic 4 are: 1) Gasoline is a bit more dangerous and volatile than diesel as fuels go. 2) Diesel engines tend to be quite a bit more fuel efficient.
If the boat is properly setup, with a bilge blower and the engine well maintained, then the danger of gasoline as a fuel really isn't much of an issue. The Atomic 4 will require more fuel to get the boat the same distance as a similarly sized diesel, but the diesel would be noisier.
sailingdog is offline
