SailNet Community - View Single Post - Centerboard cable/rope?
post #4 of Old 12-02-2013
Delta-T
Delta-T's Avatar
Re: Centerboard cable/rope?
Originally Posted by P35juniper View Post
I need to replace the cable on my P-35 and was thinking, dangerous, of using Samson Amsteel rope instaid of SS cable. My thinking is Amsteel is 5400Lb and SS is 3700Lb breaking strengh, so it should be strong enough, and if I replace it every few years, as it should be easier to replace and fairly cheap, chafe shouldn't be to bad, and no more meat hooks on the drum,
Any other issues I'm missing?
Board is strapped up for now.
Did you use the Amsteel three years ago? And has it held up? Have you looked to see if it is holding up okay? How do you connect it to the CB?
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
