SailNet Community - View Single Post - 'The Perfect Boat'
post #14 of Old 03-05-2007
goose327
2kt wind=trolling speed
goose327's Avatar
Originally Posted by donrr1
A powerboat designed to overcome hull speed needs to plane to reduce hull friction. The breadth and the relatively flat bottom of said hull requires the deck and superstructure to conform to it's design. That would make such a boat float as easily upside down as right side up. If you were to add a keel and ballast there would be too much surface area and weight to the boat to be able to get it up on plane with any reasonable amount of power and only make it more difficult to capsize. It could still be capsized and would not come back over, just sink faster with the added weight.
Don
Do you think stepping the hull(like they do for race boats)would help break the keel loose of the water?
Dale
Where are we going, and why am I in this handbasket?
goose327 is offline
