SailNet Community - View Single Post - Survey for sailors...
post #13 of Old 12-04-2013
SHNOOL
4KSB driver.
SHNOOL's Avatar
Re: Survey for sailors...
Well, it also depends on the type of sail... For instance, if you have a mylar or loadpath sail, you won't likely be sewing it (maybe, but not likely)... tape is common as is adhesive.
Also a combination of structural tape (mylar or loadpath swatches) with adhesive is a COMMON way to repair loadpath sails.
Sewing dacron is common enough, is tape. I can honestly say I've done all of the above, sew, tape, and glue, and when it was hopeless to fix, I've replaced.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
