I guess a lot of it has to do with what you're running on your boat, and the design and efficiency of the refrigeration. I have relatively modest electrical use on my boat—a small DC refrigerator, a stereo, a VHF, running lights, cabin lights, a laptop computer—and I find that solar power is more than adequate for my needs.
It also depends on how you plan and implement your solar panel installation. My two panels are setup so that one can be used with no shading whatsoever while at anchor.
A freezer, cooled by water pump, hydraulic autopilot, and satellite TV is going to draw a lot more power than I use on my boat.
As for wind generators, I am partial to the DuoGen units. They seem to be pretty well built and the added versatility of being able to use it as a water generator, means that additional electricity can be generated on long passages, without the need for running the engine.
