SailNet Community - View Single Post - Yanmar 4JH-2E using coolant
post #8 of Old 12-06-2013
chucklesR
chucklesR's Avatar
Re: Yanmar 4JH-2E using coolant
Simple, cheap and effective way to check - put dishwashing soap in the coolant tank.
If you blow bubbles you have a leak in the exhanger.
Same thing works to make sure your impeller is working (if you have an under water exhaust) - soap the impeller - crank the engine and look for bubbles.
chucklesR is offline
