SailNet Community - View Single Post - effectiveness of solar & wind
  #13 (permalink)
Old 03-08-2007
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
Mike...my opinion on the solar stick is that it is a good but expensive mounting system that provides a clear path for sunlight to your panels which helps on smaller vessels or vessels with a lot of shading. Their graphs are BS unless you are out there adjusting your panels hourly as the sun moves. My two panels were mounted on my stern rails in a horizontal position and were dual 80 watters with NO SHADING affecting them. On a good day...they produced 40-50 amps. If you get that much out of your proposed install of 100W panel even with the MPPT charger I will be surprised. If that is what you expect out of them...then write the check.
BTW...I spent 9 months at "rob the rich" in 2005!! A shame....
