SailNet Community - View Single Post - Outboard Starting Procedure
post #12 of Old 12-09-2013
chip
Fortuitous
chip's Avatar
Re: Outboard Starting Procedure
If you try to impose your will on an outboard, you're entering into a world of pain. It's best to learn what it wants and stick with that.
My process (Tohatsu 4 stroke/probably irrelevant to you) is:
  • Open air valve on tank
  • Pump the primer
  • Full choke
  • Throttle at the "start" triangle (about 1/3)
  • One slow pull of the cord, which seems to align something and keep it from bucking
  • One fast pull of the cord
90% of the time, this works perfectly (I'm crossing myself, knocking on wood, and scourging myself with a sage bush as I type this).
Hell hath no fury like an outboard scorned.
My Boat Log, or "blog" if you will:
chip is offline
