SailNet Community - View Single Post - Bottom Job
Thread: Bottom Job
post #6 of Old 03-10-2007
sailingfool
ASA and PSIA Instructor
Bottom Paint
Originally Posted by Mc51
I recently purchased a Cal24. We are doing the bottom job ourself and are in the process of sanding 36 years worth of bottom paint off. I will use west marine's ablative type anti-foul paint. Can someone tell me if I have to use some type of primer before rolling on the new paint.
Mc51
If the boat presently show no apparent blistering, I would not bother with putting on a barrier coat - no blisters, no need...unless you are dramatically changing how the boat is used, such as moving to the Caribbean for 12 months use a year, in which case it deserves some thought as a precaution.
Take a look at http://www.yachtpaint.com/usa/default.asp for excellent instructions on bottom prep, I doubt you want to use a hard paint as a primer. If you have any questions there's a free 800 number buried at the bottom of some pages. Also,if you check at West Marine, they can probably confirm the paint they sell is actually private-labled Interlux.
sailingfool is offline
