  #44 (permalink)
Old 03-12-2007
sailingdog sailingdog is offline
CD-
From what I understand, due to the difference in tensile strength, the stainless steel arches are usually fairly comparable in weight to the aluminum ones, which have to be larger and heavier to have the same strength. A few other points... 1) Aluminum is harder to repair, as welding it is more difficult to do; 2) Aluminum is subject to galvanic corrosion if you have any stainless fittings attached to it; 3) Aluminum is much more susceptible to fatigue than is stainless steel...
