SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #917 of Old 12-12-2013
Delta-T
Delta-T's Avatar
Re: Low buck projects- Let's see 'em!
PVC winter tarp frame:
No screws, no metal hardware or sharp edges to rip covering, nothing but rope and PVC (boat friendly), easy to set up and easy to store and open inside space for working. Can be made taller or shorter for your needs.
With the pitched short roof snow was not an issue so no structural ridge beam is needed, as long as there is no roof load. You can also use a 90 deg. elbow at the to ridge to get more pitch, but you will then have to tie center rope off to mast to keep for side to side movement or add interior rope gussets. And if in doubt, add a rope from the 45 deg elbow to the other 45 deg elbow on each frame section.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
The Following User Says Thank You to Delta-T For This Useful Post:
jimgo (12-12-2013)
