SailNet Community - View Single Post - Custom Holding Tank
Old 03-13-2007
Mithril Mithril is offline
Mithril is on a distinguished road
Custom Holding Tank
With the refit of my 36' steel sailboat I am planning on having a custom holding tank fabricated. Currently, I plan to have about 25- 30 gal between the wall to the head and the hull. I read a few articles on this forum so I plan to stay away from a metal tank but there seems to be some difference in opinion about which plastics to use.
What is the best material to use for a holding tank?
Some have suggested Polyethylene or High Density Polyethylene. I have also heard some recommend Polypropylene, several of the custom tank fabricators I have spoken to suggest using this material.
How thick should the material be? .25”, .375”, .5” ?
I need the holding tank to last as long as possible, because it will be a major ordeal to replace it (the cabinetry on the port side of the salon would have to be removed to gain access).
I plan to have an inlet, a discharge outlet, and a vent outlet in the holding tank. What other fittings do you think I should include? Iinspection port, a relief valve like domestic’s TankSaver, a second discharge outlet?
Anything else I should consider?
Thanks in advance for your input.
Here is a rough design for the tank as I currently see it. It would be 20 inches deep.
