SailNet Community - View Single Post - How Do You Move a Mast Over the Road
post #4 of Old 12-13-2013 Thread Starter
casey1999
casey1999's Avatar
Re: How Do You Move a Mast Over the Road
Originally Posted by TomMaine View Post
Masts quite a bit longer and heavier are moved around here on full sized PU trucks with heavy racks. Standard building contractor sort mostly, that have a forward cross bar extended over the cab.
Lashed down and with a flag on each end, I'd do the 5 miles no problem.
If you're concerned, have friends in vehicles in front and back, with flashers on.
This is how my 50' heavy spruce spar is moved to storage, down a highway, 5 miles away.
I could probably arrange the pick-up with rack as you describe. I was concerned about the long overhangs maybe permanently bending the mast. Is that a valid concern?
casey1999 is offline
