SailNet Community - View Single Post - Jabsco Electric Marine Toilet Conversion Kit
post #2 of Old 12-13-2013
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: Jabsco Electric Marine Toilet Conversion Kit
Originally Posted by capta View Post
I have installed a Jabsco Electric Marine Toilet Conversion Kit and I am very pleased with the unit.
However, when I flush, the excrement somehow flows into the rinse water and I can't figure out why. The two pumps are separated by the height of the unit, with the flush below and the rinse water at the top and the motor between. The through hulls are about 10 feet apart, so it can't be that.
Any ideas? Thanks.
The exploded drawing of the pump is available at http://www.xylemflowcontrol.com/file...43001-0524.pdf. Considering that the two pump chambers are separated by the motor itself and share no connections any cross contamination cannot be within the pump itself. I wonder if what you are observing washing into the bowl isn't contamination of the raw water rather than waste material. If the raw water is passing through a filter (it should be) it may be due to a breakdown of the filter screen material.
FWIW...
svHyLyte is offline
