SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #926 of Old 12-14-2013
trkarl
Re: Low buck projects- Let's see 'em!
Originally Posted by HUGOSALT View Post
I made a similiar frame from pvc years ago and its still going strong. If it will help, several points that have worked well on my frame...I drilled 2 holes in pvc center ridge about every three feet
for 3/4" ribs which pass though center ridge and connected 2 pieces of the 3/4"
rib material as needed then cut to desired size , they fit into holes in pvc that run along
(inside) port and starboard toe rails.(ribs and all numbered) This creates tension that works well and can be carried all the way back to the stern. Another big help is using plastic ties to hold things in place when setting up and from wind, come spring they cut off real easy.
Pretty strong, stands up to wind and snow.
Hope this helps.... Hugo
Thumbnails
I copied the entire post from the other thread because there are some really good ideas here! And, it took me a while to find the damned thread for some reason. linky
Thanks Hugo! BTW, you can get the images by hitting the quote button on the post, then copying the code.
trkarl is offline
The Following 2 Users Say Thank You to trkarl For This Useful Post:
bljones (12-18-2013), SloopJonB (12-14-2013)
