SailNet Community - View Single Post - electric winch handle
post #4 of Old 03-13-2007
sailingdog
CP-
Understandable...esp. in your case... One thing I would recommend is that you use the clutch feature on the drill, rather than have it drill mode...that way if it does hit something that causes extra resistance, you have a chance to stop, fix it and then go on, rather than just causing damage.
Usually this is more a problem on boats with the built-in electric winches, but it is a risk any time you add power to a winch, even if you do it manually.
sailingdog is offline
