SailNet Community - View Single Post - Fairing Compounds, what do "you" use?
post #6 of Old 12-14-2013
Faster
Re: Fairing Compounds, what do "you" use?
Doing this kind of work around here this time of year, I'd definitely put up a plastic hoarding (likely required by the yard in any event) and put a heater in it... very few epoxies are likely to cure properly at those temps.
We had good luck with West's G-flex resin and fillers - not so much as a generally fairing compound but specifically in the hull/keel joint area. We did have some difficulty finding it in Canada, (WM claimed to be unable to import it, but Steveston had some in stock)
Faster is online now
