SailNet Community - View Single Post - Fairing Compounds, what do "you" use?
post #8 of Old 12-14-2013
pdqaltair
pdqaltair's Avatar
Re: Fairing Compounds, what do "you" use?
Doing this kind of work around here this time of year, I'd definitely put up a plastic hoarding (likely required by the yard in any event) and put a heater in it... very few epoxies are likely to cure properly at those temps.
We had good luck with West's G-flex resin and fillers - not so much as a generally fairing compound but specifically in the hull/keel joint area. We did have some difficulty finding it in Canada, (WM claimed to be unable to import it, but Steveston had some in stock)
Remember, the keel needs to be warm' not the air. You will need to heat over night, before and after working.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
