SailNet Community - View Single Post - electric winch handle
post #10 of Old 03-14-2007
S/VNirvana
SONNY
S/VNirvana's Avatar
I had the 18 V and sold it to buy the 28V right angle drill. I use it on my SO49 to raise the main, and it's great, goes up without any trouble. I haven't used it on my Pearson 36 yet but it will be OK. I bought the drill bit from a company that makes the bit into a cube and it lasted only one season.
I found another company that sells the winchbit: I have used it numerous times and shows no signs of wear.AMERICAN MARINE SERVICES Get the power to your Winch with Winch Bit Winch Bit Makes Your
Winches Electric
The Link Between your Cordless Drill
and Your Winch
The Affordable, Portable, Winch Driver
  • Raise the Sails
  • Furl the Jib
  • Trim the Sheets
  • Go Up The Mast
  • Retrieve the Anchor
  • Hoist the Dinghy on Deck
Trims The Sheets Winch Bit converts all
self-tailing manual
winches to Electric
winches for the
unbelievable price
of $44.95, when used
with the owner’s heavy
duty 18 or 28 volt ” drill motor.
Winch Bit is made of Heavy Duty Stainless Steel with a 1/2" Shank that will fit 1/2" drill motors.
The shank is also facetted to provide a solid grip under heavy load.
Unique to Winch Bit, the 8-point bit safely distributes the load to protect your winch from damage.
Recommended: "New" Milwaukee Model 0721 - V28 Right Angle 1/2 inch Right Angle Drill with over 1000 in/lbs. of torque
Takes You Up The Mast
To order Winch Bit click on the order form on this site or go to eBay.com. When on eBay search for Winch Bit.
For further information contact Info@WinchBit.com or call
Toll Free 877-528-3415
http://mywebsite.register.com/cgi-bi...nchbit.com&P=1
Sonny
s/y NIRVANA, SO49
S/VNirvana is offline
