SailNet Community - View Single Post - Outboard Starting Procedure
post #21 of Old 12-15-2013
Re: Outboard Starting Procedure
Originally Posted by azguy View Post
Full choke and two pulls
1/2 choke with full throttle and pull till it starts
Upon ending the day, disconnect fuel line and run motor until it stops...
Careful...quirky Rude's this will also depends on the heat (or cold) of the day
You can quickly flood it with too much pulling at full throttle.
I usually choke it and pull once....then 1/2 choke and no throttle till it starts...then let it warm up and slowly "feather" the choke off....
Other times it fires up 2nd pull with no choke.
Sometimes it won't start at all..
and sometimes it's a combination of all of the above
Get comfortable in the yard with her temperament first in a barrel.
81venture is offline
