SailNet Community - View Single Post - Noise from dockline passing thru Hawse Pipe
post #8 of Old 12-17-2013 Thread Starter
mondofromredondo
Mondofromredondo
Re: Noise from dockline passing thru Hawse Pipe
All excellent suggestions that I will try. I have however experimented with different types of line. The squeak comes as the line becomes taut in the pipe and then suddenly slips/drags/rubs the contact point of the hawse pipe. I'm going to start of with fabric softener as I've heard of this before. I have tried securing loosely as well as tight with no large improvement. I am determined to get to the bottom of this. Seems I always think of this most when I'm 1/2 awake wishing I could get to sleep.
The corrugated hose sounds interesting as well as the New England Ropes.
Thanks to all !
Side note: Called Thumper at PSC this morn as I'm considering changing from the sole mounted table set to the bulkhead version. Would certainly open up a ton of space. Anyone make this conversion? Anything good or bad to say about it? I know I should probably start another thread but I'm throwing it out there. I'll bet its pricey !!
Thumper is darned knowledgeable.
Thanks All!
Keith Campbell
S/V Charity Rose
'88 PSC 34'
mondofromredondo is offline
