Jeff: Before I bid . . . T30
kevin,
the adhesive used on the keel to hull joint is usually something benign, unless the po used 5200. the only problem as i remember it is that the forward most keel bolt only visible from the little hatch in the cabin sole next to the engine is almost impossible to get to. what is the hull number. my friend had a bad 1976 that he hat tartan take back and gave him a new 1977 as a swap in 1977. i just wanted to check that this is not his old defective boat.
eric
