Thanks Jeff, I kind of like the idea of a chemical stripper better than the scraper. The idea of me using a sharp blade to gouge away at my hull isnt very appealing. I can see me causing more damage than good.
Im guessing its the "soft" type of
paint. It has a chalky quality to it, If you rub a rag over it, it will actually chalk off on it.
My next question is. When the hull was painted, the gelcoat was probably sanded in preparation so Ill have to restore that with fresh gelcoat, right? Or can I get by with just light sanding and buffing?
Another option that Ive thought of that may require less work but will solve the problem of ugly antifouling
paint is to remove the antifouling
paint thats on it now and replace it with shinier, slicker, more stable
paint of a dark blue instead of trying to restore the original antique white color of the hull.
Thanks again, Ray
