In an earlier thread, the question was asked how to replace crazed lexan glass on Lewmar hatches (see http://www.sailnet.com/forums/gear-maintenance/1245-hatch-glass-replacement.html). In this same thread, a Lewmar-certified shop, Select Plastics, in Connecticut was mentioned and I called them. But, I was shocked by the cost, approximately $300/p 22x22" hatch. I have 3 hatches. Ouch.
I'm sure this company does great work, but my question is this: couldn't most any glass company do the same thing with lexan or should I bite the proverbial bullet and just pay?
Shop around, look at local glazing companys and or do-it-yourself, if you use the smoked Lexan it is truly forgiving make a pattern and cut the plastic to match make a mould and radius it to fit your current configuration place in the oven @ 200° till the plastic relaxes and let cool naturally at the prices you quoted you could get enough practice to become an Expert
Ouch... I don't see why you couldn't just get the lexan cut to size by any competent glazier. The fitting and installation of it will be a bear, but nothing beyond what most competent sailors are capable of handling. Unless the lexan has some significant curvature to it, it really shouldn't be that difficult or expensive.
Most ports are convex and not flat, this is done to facilitate the shedding of water particularly on the deck skylights. Boatlife caulk should be used to bed the new Lexan. To remove the lexan utilize a piece of music wire and manipulate it thru the old caulk and with a pair of vise grips on each end of the wire you and an accomplice can use a sawing motion to remove the old port.
Although I have not worked on Lewmar hatches, I did build 6 new hatches for my boat in 2003. If you use Boatlife Life caulk, as recommended previously, and you're careful, you can probably replace the lexan (or use cast acrylic instead of lexan) yourself and have a leakproof job.
You got me. I was so caught up in my own evolution that I have just completed, that I didn't comprehend the question. Maybe I can redeem myself. If its just the flat Lexan that goes on top most companionways. Its pretty straight forward any glasier should be capable of replicating it. To do it yourself. Cut out the same shape/size hatch, the radius of the edges can be accomplished with a router, you need a sharp cutter and a mist of coolant to prevent smearing the material and then polish this edge with a cloth wheel and rouge. I hope that helps...
Bob, any glazier can work with any glazing. Glass, plexiglass, lexan, all get referred to as "glazing materials".
But all lexan is not the same, you will find at least a dozen grades of it just from GE (the trademark holder for that brand) alone. I would suggest that when you get estimates, get specific estimates for the exact material grade, color, and thickness that will be used. You may find a 10x difference between polycarbonates (i.e. Lexan) and acrylics (i.e. Plexiglass) and a 4x-6x difference within each material group as well.
A glazier usually will buy in full sheets (4'x8') and charge you per sheet--keeping the excess unless you ask for it. Hey, it's yours, it might be of use elsewhere on the boat. And that can make ordering replacements from a manufacturer cheaper, or competitive, since they aren't charging you for full sheets.
The proper bedding and sealing compounds can also be damned expensive, if you look them up they aren't your $10 silicone seals.<G> And, they are important. If you use the wrong sealant--you can craze the glazing.
All of the glazing materials come in different grades designed for UV and scratch resistance, and with a deck hatch you want the best resistance you can get. It is UV and petrochemical exposure that usually makes them craze.
Do you need Lexan? Possibly not. 1/2" or 5/8" thick plexi can take a lot of abuse, you'll need to decide that one yourself. Dropping a spinnaker pole from a mast mount into the hatch cover...you might want Lexan. going offshore and having green water drop 40' onto it, same thing. But many boaters don't want to pay 10x the price for the glazing to withstand that if they don't need it.
A couple other points about lexan vs. acrylic (plexiglass).
Lexan generally scratches more easily than Acrylic,
Lexan is generally more expensive than Acrylic.
Lexan is generally less UV tolerant than Acrylic.
Lexan is stronger and more impact resistant than Acrylic.
If you do get Lexan, make sure you buy the kind that is rated for exterior use, and is UV-resistant and has a scratch-resistant coating.
If you want to save some money on buying it...look for an industrial sign supply company. Many will sell a half-sheet of lexan at a reasonable price. Many will also cut it down to size for you. I got a 2' x 4" sheet of 3/8" lexan for making new drop boards on my boat from one for about a third of what it would have cost me in anywhere else.
Sabre 66 I am assuming Plexiglass. It is the main sliding hatch on an S2 9.1.
I do not know how to tell the differcne but assume if Lexan is much more expensive then most production boats have plexiglass.
BTW, just looked at the Lewmar site and their hatches are using acrylic (Plexiglas) rather than ABS (polycarbonate or Lexan).
Related Threads
1.7M posts
173.8K members
Since 1990
