post #5479 of Old 12-19-2013 Thread Starter
Elan 360
The new Elan 360 is not an entirely new boat, it shares its hull with the previous version, the 350. That could be bad news but not in this case. The 350 was a great sailing boat and its hull is still a very modern and fast one. The 360 is just a better and improved 350 and that’s good news.
The 360 is slightly lighter, has a better interior, a nicer cabin design and has a S version that is a considerably improved boat: 6% lighter with an epoxy hull, stronger laminated bulkheads and lighter furniture.
SPECIFICATION ELAN 360
Length overall ......................10,60 m | 34'9'' ft
Hull length........................... 10,60 m | 34'9'' ft
Length at waterline............... 10,10 m | 33'1'' ft
Beam.................................. 3,50 m | 11'6'' ft
Draft (standard / performance) 1,50 m / 2,15 m / 2,35 m | 4'9'' / 7'' / 7'8'' ft
Displacement........................ 5.350 kg | 11.794 lbs
Ballast (standard / performance) 1385 kg / 1300 kg | 3.053 lbs / 2.866 lbs
Water capacity..................... 175 l | 42,2 US gal
Fuel capacity........................ 75 l | 19,8 US gal
Engine.................................. 21,1 kW / 27,3 HP
Mainsail................................. 35,91 m2/ 386'4'' sq ft
Jib........................................ 29,68 m2 | 319'4'' sq ft
Gennaker............................... 110 m2 | 1.184' sq ft
Boat design category CE A
Design Humphreys Yacht Design & Elan Design Team
Prices:
http://www.argolis-yacht.com/pdf/Pri...0_01092013.pdf
