SailNet Community - View Single Post - First Boat-31' Southern Cross or 27' Hunter
post #18 of Old 03-16-2007
sailingdog
Sailormann-
The coring in the hull of the Southern Cross boats isn't balsa, IIRC, it is cored with Airex, which was IIRC a PVC-based foam. I believe the decks were cored with end-grain balsa, rather than the Airex material.
Also, many of the Southern Crosses may have been owner finished, but some were factory finished.
They may be slow, but they're very solid boats, if they were properly maintained, and are reasonably priced for a bluewater capable boat. Pat Henry circumnavigated in her SC31, and Donna Lange is about to finish a circumnavigation in an SC28. Not too many other boats can compete for the price, size and value.
One major advantage the Southern Cross has as a cruising boat is that the cabin temperature tends to be a bit easier to control thanks to the cored hull and deck. Also, it tends not to have the condensation problems in cooler weather than a solid fiberglass boat will have.
The Elizabethan 31 and the Hallberg-Rassy Monsun are two others that are about the same size and value, and with about the same capabilities.
sailingdog is offline
