SailNet Community - View Single Post - Pros and cons of steel sailboats
post #2870 of Old 12-19-2013
Ok Out, I will play your game:
Ten years ago I was still thinking that the right boat for me was one with about the same program that you see as the ideal for yourself, meaning a passagemaker for all kinds of weather, including cold climates and adapted to make a lot of sailing in the night and rain, during long passages.
Things had changed and I understood that if I wanted to keep my wife I would not be able to do that kind of sailing so the ideal boat had changed too, not to mention that I had more money then... but I still have the drawings that I never finished.
Anyway, after a very classical offshore boat (that I had already posted on this thread) I turned to a much faster and more polyvalent boat that had only in common with the last one to be an aluminium one. The drawings are 10 years and today the hull design would be different and maybe the overall design too but the principles would be about the same:
1- Aluminium very fast boat
2-A boat with two saloons, one smaller including a pilot house, where I and my wife could enjoy the scenery in cold days, another one bigger inside, down below adjacent to the galley also with a port view.
3- On the pilot house the settee would turn in a a good sea berth. Also there a good recliner seat with a big chart table with all instruments annexed and a joystick to be able to steer the boat from inside with a good all around view.
3- A big galley, and a good sea one.
4- Two good cabins and a big head with separated shower
5- a big interior storage space next to the galley.
6- Garage for the dinghy, dedicated space for the liferaft, 4 cockpit lockers, one big one, another smaller and to vertical to Stowe the fenders.
7- At least 600L of water and 400L of fuel
8- Variable draft with a lifting keel
9- Winches at easy reach to the wheel man and rigging adapted to solo sailing.
10-Retractable bowsprit.
Dimensions:
Hull lenght - 13.99m
Beam - 4.31m
Draft-1.20m/2.80m
Ballast - 4200kg
Displacement- 11 000 kg
SA upwind with jib - 115m2
SA downwind - 254m2
Some drawings:
